Having trouble getting rubber boot and spring back on
Old Jan 11, 2008 | 09:46 PM
dpv1977's Avatar
Default Having trouble getting rubber boot and spring back on
Hi, I'm trying to replace the plugs on a coil on plug northstar and am having trouble getting the rubber boot and spring to slip over both the plug and the coil...Is there a trick to this?? Thankyou for any advise on this
Old Jan 11, 2008 | 10:26 PM
Default RE: Having trouble getting rubber boot and spring back on
As long a spring is somewhat centered in boot it should be ok. You should not have try attach spring to plug or coil.When coil assembly is mounted, spring should contact both coil and plug.
Old Jan 11, 2008 | 10:55 PM
dpv1977's Avatar
Ok, thankyou again slowroll.
Showdown
May 12, 2014 05:50 PM
SloSupra
Apr 11, 2012 09:13 AM
1989 fleetwood
Feb 16, 2009 08:01 PM
1989 fleetwood
May 15, 2008 04:37 PM
Eric
Aug 27, 2006 05:39 PM
