Air suspension compressor
Old Oct 21, 2007 | 10:07 AM
bevlind@comcast.net's Avatar
Default Air suspension compressor
Does anyone know how to test the air compressor for the rear suspension to find out if the compressor itself is bad or if the height control box located by the rear shocks is the problem.
Old Oct 27, 2007 | 09:20 PM
Default RE: Air suspension compressor
Dealer has tester. This will be general no clue what year or what is wrong.With key in run.You could disconnect link from control arm and move as high as possible, compressor should come on.Once compressor is on lowering arm should turn off compressor,it lower to lowest point may hear vent soleniod release air from compressor or notice air bags on shocks deflating. Need more info to give more info.
strabo40
Mar 12, 2010 11:43 AM
cadillacmike
Mar 9, 2010 04:33 PM
motor44
Oct 10, 2007 07:02 PM
LS7505
May 8, 2007 06:46 PM
