98 Seville water in trunk
Old Apr 16, 2008 | 08:11 AM
billinohio's Avatar
Default 98 Seville water in trunk
bought car in winter and noticed ice covering spare tire in trunk. removed ice, but water remains after vac***, and air dry. power door locks, rear defrost, rear seat heaters, gas gauge, open trunk button, and gas door button stopped working. Dealer says water got under rear seat and I need new computer(?) there and in driver side door.
How do I figure out where trunk is leaking? or possible rear window? can this be repaired simply? will the electical stuff start working again once kept dry for awhile? read in this forum about possible ground wire causing elec problems...I don't trust the dealership.
Old Apr 16, 2008 | 08:18 PM
Sterling013's Avatar
Default RE: 98 Seville water in trunk
When I purchased my 2003 STS, it had the same issue. There is a bulletin on the issue involving the welds and seals of the trunk floor pan. My car was fixed under warranty. You may want to get a copy of the bulletin to see what is required to fix the problem
Old May 9, 2008 | 11:27 AM
esimp64's Avatar
Where can I get a copy of this bulletin
guintiger
Jan 11, 2018 07:05 PM
Boomer313
Apr 4, 2013 03:26 PM
edgrmndz
Feb 19, 2011 07:06 PM
billinohio
May 7, 2008 08:36 PM
threnc
Jul 9, 2007 02:09 PM
