92 Seville..Brakes making noise
Old Jul 1, 2008 | 11:05 AM
rickt7508's Avatar
Default 92 Seville..Brakes making noise
Hi all! The past few days when i press and release the brakes it makes a "zoom/vroom" like noise from inside. I had the same problem with my old car(merc. cougar) we replaced the booster on the cougar and nothing happened so i am thinking it could be the master cylinder. which one could it be..i dont want to go buy one part and put it in and it be the other.
Old Jul 1, 2008 | 11:08 PM
Katzmans Caddy's Avatar
Default RE: 92 Seville..Brakes making noise
Had a 92 Bonneville that had the master go, pretty much the same car mechanically.
Old Jul 2, 2008 | 12:05 AM
ORIGINAL: rickt7508
get under the hood and depress the brake pedal and see if that is the source of the sound.
if you hear that sound from under the dash, the seal in the booster has failed.
master cylinders dont make noises .. that i know off ...
Old Jul 2, 2008 | 08:53 AM
rickt7508's Avatar
the noise is coming from under the dash. so it is the booster[:@]
Old Jul 2, 2008 | 10:54 AM
correction
i actually meant to say : .... get under the dash and ............."
Old Jul 3, 2008 | 05:36 AM
rickt7508's Avatar
Thats where its coming from i am going to get the part today and it will be done tomorrow. Hopefully it works. Thanks guys
Old Jul 3, 2008 | 12:14 PM
upon R&R, pay attention to your brake pedal & stop light switch assy.
its the biggest pain if you forget what goes where.
also, check and see if your master cyl is leaking - if it is, replace it.
lol
Old Jul 4, 2008 | 06:57 AM
rickt7508's Avatar
i will have the mechanic check the master cylinder... i dont trust doing this myself. I'm glad my wife's family as a friend who is a good mechanic(actual mechanic owns his own business..wouldnt trust a guy who says he is one then screws it up more..had it happen)..he lets us buy the parts and he does the work for half than what others want. i will let you know when i get the car back. thank you
Old Jul 4, 2008 | 08:22 AM
that is a good thing .. there is nothing like having good brakes and tires .. saves your skin.
when i commented on the master cylinder, it was in regards to the master cyl back seal that can ruin a booster if it leaks brake fluid onto the booster seals.
one last piece of advice? flush the entire brake system. it is a good bet that your fluid is original OEM fluid, 15+ years old. do it by bleeding at each wheel until you get fresh fluid. I usually flush / bleed the system when I replace components such as brake pads and certainly a master cylinder or booster. you be smart to ignore the advice of those that say brake fluids never need changing as DOT-3 fluid absorbs water/moisture and will GEL given the right cir***stances and time. GEL fluid can bring on catastrophic failure of several components .. big $$$ !
lambeezy04
Jan 11, 2018 06:51 PM
Pastrychk
Jul 11, 2012 11:51 PM
scard
Nov 18, 2010 07:16 AM
A342195
May 24, 2009 12:52 AM
Naomizcadi
Jan 20, 2009 02:36 AM
