2002 SLS engine just stops running
Old Jun 26, 2008 | 06:47 AM
amjourney's Avatar
Default 2002 SLS engine just stops running
Hi all,
I have a 2002 SLS with about 63K miles on it. The car for the most part is a dream, but it willstall with no warning...usually when I've stopped and it's idling and I didn't give the car a warm up period. The past 2 days it's actually died while sitting and idling while I'm letting it warm up. When I go to restart, it takes longer for the engine crank to engage unless I turn the ignition off completely and wait about 5 secs before trying to restart. Also at times, when driving it will 'lurch' like its going to stall. I'll try to pull the engine codes tonight when I get home from work. Any thoughts?
Thanks
AJ
I just pulled the codes:
DDM U1301 history
U1713 history
IPC U116 history
IRCU1016 history
MSMB1860 history
U1000 history
PCM P0385 history
Since I have no clue what any of this means, could one of these codes identify why the car keeps stalling and bucking?
thanks in advance for any help.
AJ
Old Jun 26, 2008 | 09:11 PM
Katzmans Caddy's Avatar
Default RE: 2002 SLS engine just stops running
PM0385 is crankshaft position sensor and that could be the culprit.
Old Jun 26, 2008 | 09:34 PM
amjourney's Avatar
Thanks so much for the fast reply. I'll get itchecked out.
AJ
Old Jun 27, 2008 | 06:01 AM
thewood's Avatar
I agree. I had the same exact issue with my Ford Thunderbird SC and replacing the crank sensor fixed it. Don't know how difficult it is to replace one on a caddy SLS but the Tbird wasn't easy and I had it done at a shop. They charged me $100.00 extra for diagnostics although I supplied them the part knowing it was the crank sensor so be aware of that.
Old Jun 27, 2008 | 06:16 AM
amjourney's Avatar
Thanks for the info.
AJ
rico
Mar 11, 2012 05:42 PM
bigal
Sep 19, 2008 01:28 PM
carnut
Mar 5, 2008 04:21 PM
Wcandy
Nov 13, 2006 10:56 PM
Raganl
Jul 7, 2006 02:53 PM
