1993 Seville Engine Removal
Old Oct 10, 2008 | 04:50 PM
Marty_Swindle's Avatar
Default 1993 Seville Engine Removal
Have a 1993 Seville STS that has a bent rod or shaft or something (sucked in a bunch of water during the last hurricane). I have removed the subframe/engine/trans assembly from the car. Now I have that assembly in my garage and want to lift the block off to get to the oil pan to see what the real problem is. I have an engine hoist but can't see where to connect to the block to lift/slide it away from the transmission. Is there something that I am missing?
I saw somewhere else on this forum that someone had provided detailed drawings of how to remove the head gasket which included the removal of the transmission. Reference the post below:
Cadillac NorthStar Headgasket replacement by the book
There was nothing about moving the block around once it is disconnected from the frame. If there were some other drawings like that it would be most helpful.
Any suggestions would be greatly appreciated.
Marty
imageres
Aluminum Block V8s
Jun 17, 2011 07:20 AM
kfingerle
Jan 19, 2009 08:24 PM
Marty_Swindle
Oct 14, 2008 11:14 PM
Dave S Texas
Oct 3, 2008 09:36 AM
jholland250
Oct 4, 2006 08:04 PM
