struts - Cadillac Allante
Old Aug 29, 2007 | 11:14 PM
wcoates's Avatar
From: Canfield, Ohio (halfway between Cleveland and Pittsburgh)
Default struts - Cadillac Allante
For my "89 I took the 88945832 front AC-Delco Struts(503-352) to local Mechanic (good and I trust him) who has called me with what he perceives as a problem. He is saying that the tire (Running new 225/60/16 for the last year w/o any difficulty instead of of 55's) is resting right against a flange? on the new strut. Says it looks like the old strut had said flange bent out of the way. Any thoughts ? thanks!
Moderator Edit
Title
Old Sep 1, 2007 | 11:22 PM
Default RE: struts
i seen a lot of chatter over the years about the dangerours small clearance,
but this is the 1st time i hear about actual contact. Personally, I be a bit nervous.
Did you get a picture of the fit?
I like to see a pic posted as that usually helps understand the issue a bit easier.
Old Oct 11, 2007 | 08:37 AM
Default RE: struts - Cadillac Allante
Maybe Fox can enlighten us with part numbers on what her '93 is wearing.
Apr 25, 2023 05:44 PM
Cadillac Allante FAQ
May 27, 2013 12:44 AM
DavEldorado
Dec 15, 2007 09:20 AM
Dec 1, 2007 01:46 PM
sabreman23
Nov 14, 2007 01:39 PM
