More strut stuff... Cadillac Allante
Old Aug 30, 2007 | 12:18 PM
foxpaws's Avatar
Default More strut stuff... Cadillac Allante
I need to replace the struts all the way around on my'93. No hurry - but the rears are leaking a little, and the fronts are just getting old. I bet this thing would handle a whole lot better with some new struts, and I am having them replace a lot of the bushings as well - it is just starting to get a little "sloppy" on the road.
What did you do - I want passives on the rear - it needs to be stiffer I noticed there are a couple of aftermarket brands out there - what are they like and do you have any recommendations?
And what about the front? Is there anything available other than Caddy for the 93s - or is the front the same on other years?
Thanks!!!!!!
Moderator Edit:
Title
Old Aug 30, 2007 | 10:18 PM
Default RE: More strut stuff...
starting to sweat the idea of the run up the L.A.Crest Hwy ?
[IMG]local://upfiles/2893/7623C1B16D7445869D1F8565AE0C96A0.jpg[/IMG]
Old Oct 11, 2007 | 08:40 AM
Default RE: More strut stuff... Cadillac Allante
Fox,
what was the final outcome? parts #'s, model, etc..
you got a new set, right?
Old Oct 11, 2007 | 11:10 AM
foxpaws's Avatar
Sorry - the Arnott struts are only for '93 - but here is the link:
http://www.arnottindustries.com/part...d6_ pid80.html
The struts ran about $600 with shipping - the sway bar links/strut mounts/bushings another $300 (approx) I am not sure but I think the sway bar links are stock - K&N strut mounts - and a combination of stock rubber bushings for the ones that rotate and poly for the ones that compress.
Install was another $400
I posted more on the switch in your aftermarket section...https://www.cadillacforum.com/m_13248/tm.htm
G.A.R.Y.
Aug 7, 2013 10:05 PM
jonlisa97
Dec 1, 2012 08:47 AM
vettelover91
May 7, 2012 01:29 AM
cap4000
Cadillac Allante FAQ
Jul 9, 2007 04:06 PM
PhantomR/T
Mar 1, 2007 01:57 PM
