Trans trouble?
Old Jan 17, 2008 | 06:18 PM
bigboi85's Avatar
Default Trans trouble?
I took a drive today, about 30 miles total mixed highway/city. On my way home the car started to shift funny and shudder a little when I would take off from a dead stop. I have been warned against trans flushes, why? I havent changed the fluid or filter yet so I should do that at least right? I just had the oil changed and the radiator flushed and filled. They checked the fluid and said that it was full and looked ok. What gives?
Old Jan 17, 2008 | 07:55 PM
Default RE: Trans trouble?
It's hard to advise without a road test. Try to be more discriptive. Also note what speeds trans is up or down shifting at when it's acting up. Check for codes. Then repost. You might also find a trans shop with a good rep in your area, if a visit is required.
Old Jan 21, 2008 | 05:36 PM
bigboi85's Avatar
OK how do I check the codes? And there isnt a good trans shop anywhere near me to help. So the fluid and filter wont help much? And also why is the flush not a good idea? Thanks for all your help guys.
Old Jan 21, 2008 | 07:46 PM
To get codes press off and warmer(red) button on ac control head. codes will display E._ then 7.0.
Flushing trans fluid if you already have transmission troubles can make them worse.
newfdog
Sep 1, 2008 09:13 PM
04CTSChick
Automatic Transmissions
Aug 12, 2008 02:20 PM
bishopxm
Mar 5, 2006 09:32 PM
crosscomp
Dec 5, 2005 07:30 PM
dr.franz.rahn
Nov 30, 2005 03:36 AM
