Blower Motor Control Module (BMCM)
Old Aug 12, 2010 | 10:30 PM
jpw46's Avatar
Default Blower Motor Control Module (BMCM)
The bmcm controls the fan speeds. On my 88 Fleetwood the blower all of a sudden shifted to hi speed and I could not turn it off. After arriving at home I took all the fuses out and the fan continued to run on hi so I disconnected the battery and it quit running. I obtained a used bmcm and after installing the fan worked great. However, the next day after driving for about 5 minutes the air shifted from the dash vents to the floor vents. The air is still cool, but I can't get it back to the dash outlets. Any ideas--please let me know. JP jpw46@yahoo.com
Old Aug 15, 2010 | 09:01 PM
Cadsforfun's Avatar
Default mode door
Bad signal being sent to the mode door unit which is in behind the glove box. Mode door determines which vent duct the air goes to, pull out the liner and see in the motor is functioning properly.
Old Aug 16, 2010 | 08:23 PM
jpw46's Avatar
Cads--Thanks for your recommendation, I'll give it a look see.
Additional information: 1. After driving for about 20 minutes I can sometimes trick the system by selecting defrost. The air will slowly shift, but not all the way, then I can select auto and the air will slowly shift to the dash, but still not all the way, but it makes it much more tolerable in this GA heat.
2. I may also have a vacuum problem also--the cruise control is slow to catch on and periodically when cruising on the hiway it will break cruise and I have to re-set. JP jpw46@yahoo.com
Old Aug 17, 2010 | 05:30 PM
Cadsforfun's Avatar
Default mode door
The reason for the slow change, as I have found, is the fact that the hinge on the mode door gets rusted from condensation in the hot cold chamber. When it gets rusteds the mode door will neither close or open completely. Get in behind the glove box and spray some wd40 or other lub on that hinge and free up the mode door to do its thing.
mrklean
Apr 12, 2012 09:07 PM
phut7
Oct 21, 2010 09:54 AM
DevaJones
Jun 5, 2010 09:34 PM
cunnidj
May 1, 2009 01:41 PM
Mar 5, 2008 11:18 AM
