A/C warm when stopped
Old Aug 10, 2008 | 08:35 AM
tommygunner06's Avatar
Default A/C warm when stopped
A/C is cold when moving,,when stopped it warms up. On a 2002 escalade. Is fan clutch going bad(it spins real easy when engine is off) or do I need a extra(aux) cooling fan on front of radiator?
Old Sep 9, 2008 | 01:51 AM
g8khf's Avatar
Default RE: A/C warm when stopped
Check if you have an electric fan and is it working?. You need to put some gauges on the A/C to check running pressures. I suspect you may havelow gas level as the high pressure cut switch would trip if the condenser did not have air passing through it.
Check:
1. Electric fan (if fitted) operating correctly.
2. Clutch not dropping out
3. Running pressures.
If AC has not been checked since new, the I would say you are low on gas; it leaks out eventually as car AC is not hermetically sealedunlike domestic systems.
Old Sep 9, 2008 | 09:12 AM
ORIGINAL: g8khf
Check:
Ditto
sknovr
Dec 20, 2016 07:03 PM
johnnyjaws
Mar 26, 2011 08:50 PM
WolfmansEldorado
Mar 11, 2009 08:00 PM
bighank
Jan 4, 2008 09:02 AM
rwalkenhorst
Jun 22, 2006 10:39 PM
