Air ride control
Old Mar 4, 2009 | 05:27 PM
EscaladePatrick's Avatar
Default Air ride control
Just wondering if there is anyway to control factory air ride on my 2004 Escalade? I'm just looking to raise it a bit at times and lower it a bit at others. I looked into aftermarket system but can afford it.
Old Mar 6, 2009 | 06:16 AM
JDTDBD's Avatar
I have an 03 with air ride aswell, I have been looking into a 2/3 drop kit so I have been researching the suspension quite a bit. The Air Ride basically is talkinig about a compressor in the rear of the truck that airs up the shocks in the rear end to keep it level when a heavy load, or more passengers or towing is happening. There are sensors back there that have factory settings. The sensors have no settings, infact the lowering kit says to bend the sensors to keep it from airing back up to factory ride height. Your pretty much stuck with what you have, the only way to adjust ride height is by "bagging" (Air Bag Suspension) your lade. And that is $$$$$. hope this helped.
Old Mar 7, 2009 | 10:24 PM
I knew that it didn't have any settings, but thought that there may be a programmer out there that could make some adjustments. Thanks for the help.
raceytracy
Feb 25, 2013 08:38 PM
98eldogg
Aug 7, 2011 10:46 PM
dick schulz
Jul 10, 2010 10:43 AM
e052756
Oct 5, 2007 05:48 PM
chuckchatman
Mar 7, 2007 11:47 PM
