04 EXT problems; knocking, steering
Old Feb 26, 2008 | 08:31 PM
RidinDirty's Avatar
Default 04 EXT problems; knocking, steering
Hey guys, Man I may have gotten in over my head and most of you probably are thinking WTF. Ok so I wanted a badass upscale sporttruck, i bought an 04 EXT. I proceeding to spend alot of money for bolt ons and achieved around 400hp. So now I am having troubles. I have a cold air intake and a BBk throttle body and now I am having knocking, which is more like burping in idle. I put in new spark plugs and wires and every fuel injector cleaner they make( I prefer Lucas). So is it possible the OEM MAF is not able to compute the new are ratios the bigger intake is making or do I need to coils?
OK #2 question. When I make turns the suspension feels rough I can hear a knocking noise and I can feel the bumps through the steering wheel actually like the steering column is loose or rattling, but upon inspection its tight, and itdoesnt do it whendriving straight.Also plenty of fluid in the reserviour. Any ideas? Thanks guys
Old Feb 27, 2008 | 05:46 PM
Default RE: 04 EXT problems; knocking, steering
Q2 likely intermediate steering shaft.
Q1 ecm calibration possilby, suggest have someone local familiar with your mods help you out. Chevy sites may also be helpful, but I believe you need someone with scanner to sort it out.
Old Feb 27, 2008 | 05:59 PM
RidinDirty's Avatar
Thanks, Im going to take a look under the hood this weekend, see if there is something i missed that might be loose. thanks again.
Old Feb 27, 2008 | 06:17 PM
Intermediate shaft will be fimly attached, but slip joint in shaft will cause noise and knocking in steering wheel. If mileage is low maybe be able to get covered under warranty.
Old Mar 5, 2008 | 09:18 PM
RidinDirty's Avatar
SlowRoll, ive been doing some research, for money sake i was thinking about cleaning the filament and connection on my MAF to see if its dirty ( I did remove the screen for less restriction), one post I saw said to disconnect the MAF sensor and drive around for no more than a half hour to see if you have the same sluggish idle problems to see if its actually the MAF. Do u see a problem with this? currently there are the CEL's displayed.
Old Mar 5, 2008 | 09:21 PM
RidinDirty's Avatar
PS, after some more investigating, GM apparently got the int. steering shaft all wrong, and a short fix was extra lube, It seems Dorman now has an int. steering shaft with D knuckles (part # 425-176) that eliminates the problem, If its not covered under warranty I can pick the part up for about 50 dollars, thanks for the help!
ross.virant
Cadillac EXT
May 31, 2012 02:59 PM
alvin
Apr 4, 2010 01:16 PM
aaronbently
Feb 15, 2008 06:08 PM
alvin
Feb 22, 2005 05:40 PM
