hesitation...i think
Old Nov 23, 2006 | 12:46 AM
JoweeCadillac's Avatar
Default hesitation...i think
OK, I have a 94 ETC with 82K. The problemo I am having is when I take-off (leadfoot it) from a stop sign or green light faster than in normal acceleration. The car seems to hesitate, i guess is the word for it? It feels almost like the transmission is slipping, or it isn't getting enough gas. The transmission is brand new (2yrs old) so I really don't think it's the tranny since I have no problems with it...I think. When accelerating, it shifts perfect when driving normally. After a few seconds of "the hesitation" I am experiencing, it stops and it's almost like a turbo kicks in and really feels how it should be. This is very annoying, especially since I can't get the full thrill of the Northstar power! I read through all the forums and can't find any with this type of issue. I would appreciate it very much if someone could help me =]
Thanks
-Joe
Old Nov 23, 2006 | 01:09 AM
brougham1's Avatar
Default RE: hesitation...i think
Hey JOWEE: If you are standing in front of the car with the air cleaner off do you see a device on the left side of the Throttle body that is connected to the throttle valve shaft. If so this is the TPS (throttle position sensor) It tells the computer what position the throttle is at so it can adjust the timing appropriately. If you have this on your engine then it is adjustable. It made all the difference in the world when my car had the same problem. If you don't have this on your ride, then the timing may be the issue. Hope this helps.
Old Nov 23, 2006 | 01:49 AM
Thanks alot!!!! I'll have to check that out and I will let you know if that was the problem.
ctfh
Sep 23, 2008 11:27 AM
ctfh
Sep 1, 2008 10:04 PM
Seanyboy
Aluminum Block V8s
Aug 7, 2008 09:18 PM
myheadache
Aug 20, 2007 08:50 PM
PMPN8EZ
Feb 21, 2006 07:08 PM
