Help! I Need Another Ignition Key for My 1994 Eldorado!!!
Old Aug 31, 2018 | 02:00 PM
CH67guy1's Avatar
Default Help! I Need Another Ignition Key for My 1994 Eldorado!!!
Hello Forum,
I recently purchased a 1994 Eldorado.
Sadly, the seller could only produce 1 original ignition key.
I was told the other original ignition key (and a gold key, at that!) was buried along with a previous owner of the car.
Should I be wanting another Pass Key II ignition key, and if so, how do I get one?
Or should I focus on disabling this theft deterrent system?
Thank you for your thoughts!
Charley
Old Sep 1, 2018 | 02:47 AM
Jenyk's Avatar
Measure the resistance between black element contacts on the opposite sides of the key you have got (I assume it is working). Then choose the right key here: https://www.keycraze.com/vats-keys.html. Just check there the correct type of key. It worked for 93 Sixty Special, so 94 Eldo might use similar, if not the same, system.
Old Sep 1, 2018 | 09:50 AM
CH67guy1's Avatar
My ignition key measures 692 ohms, by my meter.
That corresponds to a single cut VATS key 3.
Thank you very much for your help!
Old Sep 6, 2018 | 06:32 PM
87allante's Avatar
often cheaper to just cut the wire (orange I think but not sure, do not touch the yellow that is airbag) where it comes out of the column, solder the proper resistor across the two leads heading back towards the firewall, tape it up - then just go get a copy of the key at a good locksmith - no more resistor needed in the key
Old Sep 7, 2018 | 03:04 PM
CH67guy1's Avatar
Is there any downside I need to know about if I choose to go this route?
Old Oct 9, 2018 | 07:48 AM
CH67guy1's Avatar
I was able to get a VATS key cut for my 1994 Eldorado.
$27.81
After the key was cut, initially it would not turn in the ignition. But the guy tweaked the new key a bit (With a file? I didn't see what he did.) and got it to work just fine.
HIGHLY RECOMMENDED:
Homecraft True Value Building Center
3407 Library Road
Pittsburgh PA 15234
(412) 884-7900
87allante
Jun 7, 2019 06:41 PM
JonsCaddy
Feb 22, 2012 07:32 PM
llwta76
Aug 20, 2009 09:18 AM
llwta76
Aug 15, 2009 10:54 AM
marwana
Feb 13, 2009 06:09 PM
