codes what do they mean?
Old Nov 14, 2007 | 12:47 PM
pepsipackin's Avatar
Default codes what do they mean?
I have a 94 Elderado and im am having trouble with the shift of auto tranny. the car runs good but when i start off it will shift but whenit gets near 35-40 nothin shifts is this bad and what do i do to correct it?? the code are po29 po94
thanks for any help that you can give
Old Nov 14, 2007 | 11:49 PM
Default RE: codes what do they mean?
ORIGINAL: pepsipackin
recently i noticed a problem with my tranny. I have a 94 Eldo 127K miles on it. The display said to change trans fluid so I had it serviced. They changed the fluid, filters and gasket. That did not correct the problem. around 40 whern the tranny is suppose to switch gears it doesnt. I have check the codes and they are PO29 and PO94. Any idea what it may be and what action can i take to correct this problem. any suggestion would be greatly appreciated.
thanks
from your other double post .. please keep it to one post with all details on the one post.
Gear solenoids not working. It is bad.
A good TECH can change them out without dropping the tranni or doing an overhaul.
However, if your transmission is low in fluid, it can do also do that.
[IMG]local://upfiles/3799/D077FEF4FC0045B78C33CE09530FF7B5.jpg[/IMG]
edmund
Jun 28, 2008 11:21 AM
dhsman
Oct 19, 2007 10:32 PM
rbradney
Oct 14, 2007 06:20 PM
JP500
Sep 3, 2007 07:13 PM
unkut
Apr 1, 2007 10:14 PM
