codes what do they mean?
I have a 94 Elderado and im am having trouble with the shift of auto tranny. the car runs good but when i start off it will shift but whenit gets near 35-40 nothin shifts is this bad and what do i do to correct it?? the code are po29 po94
thanks for any help that you can give |
RE: codes what do they mean?
ORIGINAL: pepsipackin recently i noticed a problem with my tranny. I have a 94 Eldo 127K miles on it. The display said to change trans fluid so I had it serviced. They changed the fluid, filters and gasket. That did not correct the problem. around 40 whern the tranny is suppose to switch gears it doesnt. I have check the codes and they are PO29 and PO94. Any idea what it may be and what action can i take to correct this problem. any suggestion would be greatly appreciated. thanks Gear solenoids not working. It is bad. A good TECH can change them out without dropping the tranni or doing an overhaul. However, if your transmission is low in fluid, it can do also do that. https://www.cadillacforum.com/upfile...09530FF7B5.jpg [IMG]local://upfiles/3799/D077FEF4FC0045B78C33CE09530FF7B5.jpg[/IMG] |
