2006 DTS - Performance V8 running very rich / engine vibration
Old Oct 29, 2020 | 06:49 PM
GoneGolfing's Avatar
Default 2006 DTS - Performance V8 running very rich / engine vibration
Need advice.
  • New coils, wires and plugs, 3000 miles ago.
  • New Water pump,
  • New alternator,
  • New power steering pump.
  • New purge valve (3 weeks ago) - checked and no issues
  • 130,000 miles
  • Engine started running rich while driving ( local 30 MPH)
  • Only code is P0300
  • engine coolant temperature sensor - no issues
  • MAF sensor - no issues
  • MAP Sensor at idle is showing 2.5volts and should only show 1 volt. The sensor was swapped out and the new one had the same issue
  • above 2000 rpm the problem of running rich goes away
  • O2 sensors swapped out for check - no issues
  • Mechanic has checked all sensors, checked all injectors, checked all plugs, looked at wires controlling individual injectors, can not determine what is causing the engine to run excessively rich
Looking for advice on what else could be causing the problem.
lugnut68
Nov 2, 2019 02:15 PM
hydeste1
May 23, 2019 02:00 PM
rico
Mar 11, 2012 05:42 PM
Ronin
Aug 7, 2009 05:10 PM
cummins777
Aluminum Block V8s
14
Dec 9, 2008 06:53 PM
