Window Switch Removal
Old Sep 25, 2008 | 08:01 PM
mechanical man's Avatar
Default Window Switch Removal
I need to replace the electric window switch pack on the driver's door. Does the whole door panel have to come off or does the little panel the switches are in pull out?
Chuck
Old Sep 26, 2008 | 01:03 PM
Katzmans Caddy's Avatar
Default RE: Window Switch Removal
Don't see the year of your Deville listed but generally the panel will lift out. The design is usually such that you push panel towards rear of car then lift up on the front. I usually use a wide flat blade screwdriver for this being careful to pry up the front a bit then push back and lift out.
Connectors also have locking tabs and you'll need a very tiny flat blade, like the size to repair spectacles, to disengage these. Don't force anything out.
Old Sep 29, 2008 | 06:28 PM
Yeah, I realized that I forgot the year/model a few moments after posting. It's a 98 Deville Concours. I tried pulling from the back to no avail. I will try from the front this time.
chuck
98 Deville Concours
Old Sep 30, 2008 | 08:44 AM
I have the same car, it comes out pretty easy actually. Just replaced mine in the spring.
Old Oct 19, 2008 | 07:51 AM
Katzmans,
I went out today and tried to push the panel back and pull up but it didn't seem to want to come out. How hard should it be to pull up? It looked like it was still captured midway down the panel. I didn't want to break anything by pulling too hard.
chuck
98 Deville Concours
Old Oct 19, 2008 | 09:13 AM
EricD's Avatar
I have found some come out easier than others. Try another switch. Once you get one out and see how itsmade you should be able to getyour problem switch out.
Old Oct 19, 2008 | 01:51 PM
Katzman,
OMG that was easy! I looked at the passenger side on-seat control panel which had come loose in one of my kid's hands. A little more oomph on the screwdriver and "pop" it came out-took all of 45 secs to swap switches. This is one place manufacturing ease of assembly makes repair a snap-litterally! Thanks for the guidance. All windows working from the driver's console now.
chuck
98 Deville Concours
Old Oct 19, 2008 | 03:58 PM
Sorry I was busy this week and just see your pĂ´sts. Glad it came out and all windows are operational. Now you just saved yourself about $75 labour ! Feels good eh.
Old Oct 19, 2008 | 05:55 PM
Katzman,
I am a regular DIY'er and a 30+ year mechanical engineer. If the repair shops had to make a living on what I pay to get repaired, few would exist.
chuck
98 Deville Concours
78 C-10 Custom Stake Body
82 Avanti
77 Bronco
96 Jeep Cherokee (the wife's ride)
06 Toyota Sequoia (I operate under the one good car theory)
Old Oct 19, 2008 | 06:01 PM
ORIGINAL: Katzmans Caddy
Sorry I was busy this week and just see your pĂ´sts. Glad it came out and all windows are operational. Now you just saved yourself about $75 labour. ItFeels good eh.
