whats a good running temp?
Old Jul 15, 2006 | 06:47 PM
tcooper2's Avatar
Default whats a good running temp?
i posted a while back about my 96 deville running hot,(tnks 4 d replys) well i put a new water pump and a inlet housing and hoses($800) and that seems to help. but the temp reading has me a little worried, before all of the work it was running at 197-211, now its running higher200-233 it went as high as 237. what is the avg. running temp. and do i have another problem on my hands. by the way the themostsat was also replaced.
Old Jul 16, 2006 | 09:30 PM
FLCaddytech's Avatar
Default RE: whats a good running temp?
It may have air stuck in the system. Check the level to make sure it is full.
200-220 is normal.
237 is a bit high. Was that driving or sitting still?
Old Jul 17, 2006 | 05:01 PM
tcooper2's Avatar
that was drivivg. i was told by a mech. today that i need a new head gasket. he said it was best to just replace the engine.[:@] i don't know what to do. i haven't seen any water in the oil or any white smoke from the exhaust. it's not blowing coolant from underneath. but i'm just at a lost for words and $$$$$. any suggestion on a reasonable engine would be greatly apperciated
Old Aug 2, 2006 | 05:15 AM
hagrid's Avatar
coming from a bit similar situation, what I did is I disconnected the heater hose from the exhaust manifold to prevent hot air into the manifold.
you may need an engine mount for that. make sure the coolant sensor is also working properly.
lyoung48
Jun 25, 2007 04:17 PM
will albers
Aug 23, 2006 01:02 PM
incogneatto2000
May 6, 2006 05:10 PM
BOBPRICE
Dec 5, 2005 02:35 PM
