Strange problem for 92 Coupe DeVille
Old Jan 6, 2007 | 06:29 PM
Cadillac Pimpin's Avatar
Default Strange problem for 92 Coupe DeVille
I'm about to buy a near perfect 1992 Coupe DeVille with 79,650 miles. What's troubling me is the fact that a fan for the AC system I think won't turn off when I shut the car off during the test drive. The owner is puzzled by it too, since this is the first occurance he's known of it. We tried unhooking the battery, waited 30 seconds and then reconnected it, but it turned back on. Please help, as I would really like to buy this car without having to spend a huge amount of cash,figuring out what the hell is wrong with it.
Old Jan 6, 2007 | 07:14 PM
FLCaddytech's Avatar
Default RE: Strange problem for 92 Coupe DeVille
Unplug the fan control module. Its under the hood on the firewall.
Old Jan 6, 2007 | 07:31 PM
Where exactly is that, like (left or right side) or whatever. A diagram might help me too, as I don't know what the module looks like.
Old Jan 7, 2007 | 01:14 AM
jetstar63's Avatar
My 1989 De Ville had the same problem and it drained the battery down flat. Clean the battery terminals, turn the ignition onand with a multimeter set to the 20V positiondo a load test on the battery to determine if the voltage is in the range of 12 to 14 volts. It should not go below 11.5 volts. Wear safety goggles when working on the battery.
Sufficient power is necessary for all electrical systems to function properly. Make sure that before you disconnect or reconnect wiring to first remove the negative battery cable to protect the delicate electronic circuitry.
Old Jan 7, 2007 | 01:29 AM
It must be the module because it has a brand new battery.
jim_h_erie
Sep 21, 2010 11:14 AM
LonnieChrisman
Jun 13, 2010 07:37 PM
firesubc
May 16, 2010 06:10 PM
mxblue23
Mar 13, 2006 04:28 PM
mxblue23
Feb 28, 2005 04:41 PM
