Rear window subwoofer
the sub is a bose 10" you should be able to access it from the trunk to disconect the wires and you will have to bend the metal tabs straight that anchor the cover down over the sub. then from the back seat you should be able to lift the cover and get to the screws. You may have to get a chiltons or haynes to tell you more but im not sure if they say much.
I have one , it's a Bose, and ii believe it's a 12" speaker
