Rear window subwoofer
Does anyone know what size the rear window subwoofer is and has anyone replaced it and what brand sub did you choose? Mine sounds busted. I want to know before I start dismanteling it.
Can somebody answer this? Mine just went out and I just assumed i could go buy any sub to put in there.
the sub is a bose 10" you should be able to access it from the trunk to disconect the wires and you will have to bend the metal tabs straight that anchor the cover down over the sub. then from the back seat you should be able to lift the cover and get to the screws. You may have to get a chiltons or haynes to tell you more but im not sure if they say much.
Originally Posted by Dham
(Post 8773)
