Please help! 1988 cadillac sedan deville turn signal switch is broken
Old May 18, 2017 | 07:22 PM
Rontay's Avatar
Default Please help! 1988 cadillac sedan deville turn signal switch is broken
I have an 1988 cadillac deville. The problem is that my turn sit an switch is broken inside the steering wheel. Well I thought it would be an easy fix but believe it or not, the steering wheel will not come off. Yes I have tried everything to get it off. I even went to another mechanic who tried to get it off and was unable ti. It is like it is welded in or something. Since I can't get the wheel off I was jist going to replace the entire column but I can not find a steering column to fit to save my life. Does any one know how I could install some sort of switches in order to use my turn signals? I'm open to any ideas and suggestions. I even thought about installing some aftermarket turn signal lights but I'm still debating that. Please help.
Old May 19, 2017 | 12:31 PM
You could plug new switch in and lay the switch out of the way until you can repair/replace column. You would has to turn switch on and off since uninstalled it can cancel on it's own.
Old May 19, 2017 | 10:01 PM
Rontay's Avatar
Thanks slowroll. That is a great idea. I will try that tomorrow. I ordered the part so hopefully I will be able to plug it in and use it. I will let you know.
Old May 21, 2017 | 05:58 PM
Rontay's Avatar
So...i tried the new harness. It worked as for as being able to manually switch the turn signals on and off. But since I can not hook it up in the steering wheel, the horn does not work or the hazard lights. I guess that switch has to be touching some metal parts in the steering wheel or column. So I was thinking....is there any way I can plug up a switch the the turn signal wires on the original harness? If I can find the wires, how do they work? When you turn on the turn signal light, which wires activate in order to turn them on?
Old May 23, 2017 | 09:42 AM
the cam switch right or left for turn signal. the little square button with a screw hole is for the hazards. inside the little tower is the contact for horn, there are 2 exposed contacts on top are for key reminder
RawKnee's79
Vintage & Classic Cadillacs
Sep 26, 2014 08:08 PM
Michaelwil
Jun 25, 2014 08:22 AM
CadillacAttack.
Eldorado Seville
Dec 30, 2013 09:16 PM
nunezm08
Dec 11, 2012 08:53 PM
prob aller6968
Jul 3, 2006 08:51 PM
