Passenger side A/C always hot
I took the car into the dealer because the passenger side blows out only hot air. Dealer says they hooked up a scanner and could not get the passenger side actuator to work through the control head and THINKS the control head is bad. New control head is $600 plus labor. Is there any way to manual move the actuator to allow cold air? Also the rear is blowing just hot also so I am assuming it is controller by the same actuator. I believe this is the one behind the glove box which I understand you have to take out to get to it. Thanks for the help!!!
Actuators fail more often than control heads, they are less expensive also. Dealer's Tech 2 scanner would be able to move door where ever you want it if control head is bad...overrides control head commands.
When you check the actuator, you can verify that the control is sending the correct signal with a voltage meter. Unhook the connector and put a voltage meter on the second pin from the end, the one with the dark blue wire. The voltage should vary between 0, 2.5, and 5 volts as the control is moved. The amount of the voltage controls the door as follows: 0-1 volts moves the door toward full hot. 2.5 volts stops the door at that location. 4-5 volts moves the door to full cold.
The actuator compares the control voltage to a reference voltage when controling the door, so another possible cause to your problem could be a short to ground on the 5 volt reference signal. Check the end pin with the grey wire and verify that there is 5 volts at that pin with the ignition ON but not running.
wrathofdad
Oct 26, 2011 06:47 PM
