need help tuning a 66 429bb
Old Aug 27, 2006 | 02:29 PM
eyepoppin's Avatar
Default need help tuning a 66 429bb
need some info please about carter carbs and timing and points setings
cant figure out y it runs so rich
Old Aug 27, 2006 | 02:51 PM
brougham1's Avatar
Default RE: need help tuning a 66 429bb
Hey there eye poppin: When your carb runs rich it will usually mean that your float setting is too high. You can pop the top off to get at the float chamber and hold the float arm with a screw driver and bend the float down a tad. This will allow the needle valve to be closed sooner, thus run leaner. You can bend it too much and have the reverse effect because a lean engine will sometimes run too hot. Hope this helps.
daviddi888
Mar 10, 2009 10:46 PM
2TONFUN
Aluminum Block V8s
Apr 11, 2008 12:18 AM
ggoodling
Sep 8, 2007 04:12 PM
stbtt
Aluminum Block V8s
Dec 28, 2006 05:18 PM
