License Plate Light
Alright, My License plate light assembly only has one small bulb in it. Its ultra dim. Everything is good with it, I got Full Volts coming to it... good ground and even put a LED bulb in it. Which that helped quite a bit. But Normally there are 2 bulbs in each license license assembly... do the later model devilles have 2 bulbs? I need some ideas. Thanks ahead of time!
i guess ???? whats your point??? oh, you want to make sure the po-po can read your plate when your running down the road at 100mph.... lol. if it works, whats to fix?? are you modifying the lights on the car??
brickellk
Sep 15, 2012 09:07 AM
