Help Please!! 1997 Cadillac Deville head gasket ?
I have never had it done, but in 2000 Cadillac went to an air cooled conventional system because of the leaking problems. The parts are specially bent aluminum lines and hoses so in themselves not expensive but it is tight in there and probably a 1 to 2 hour job on the flate rate scale.
The proper proceedure is to get the sealer and pellets into the radiator as I mentioned, but given the fact that you need to take the rad hoses off to do this that was going to be tough. They should be in the rad. The sealer is most likely gone by now, hopefully into the engine and having the pellets sit in there is not perfect. They will eventuallybreal downbut they need coolant to do so. I assume you have not overheated, just low on coolant. Get the pressure test and this will pinpoint the leak. Once you sort out the leak the sytem should be flushed and cleaned and that will take care of the pellets.
ORIGINAL: Katzmans Caddy
You need to get a pressure test. IMO that other article is reactionary and alarmist.
This person used to be on another board and had to terminate further postings for reasons. He gave a wealth of info to allante owners, and we all miss his hands on knowledge.
In any case, after being here a short time, I believe that you know a whole lot about these engines also. Perhaps that info is dated. If so I will be happy to request that it be removed.
What do you think?
G.A.R.Y.
Hey G.A.R.Y. - All I'm saying is that it probably scarred the heck out of Sandi, yes the pellets are recommended to be installed in the lower part of the radiator as Cadillac specs them. I think all information is good, especially from an engineer. I'm just an accountant who has worked on cars since I was 15 (almost 35 years) but I'm taking the part about the pellets in the reservoir ruining the cooling system with a grain of salt.
To Sandi - I bet you changed the front 4 plugs, just a hunch! No burning rubber! Please get a pressure test to settle the coolant loss. You can't be adding coolant this often. Once you fix it clean and flush your cooling system.
