hard to start
Old Nov 5, 2006 | 01:42 PM
kgn552004's Avatar
Default hard to start
apparently my cadi doesn't like cold mornings.......i have a hard time starting it in the mornings.......i have had it in the shop twice for cold start............does anyone have any suggestions?
kgn
Old Nov 5, 2006 | 04:00 PM
FLCaddytech's Avatar
Default RE: hard to start
It would help to know the year and engine you are asking about.
Old Nov 8, 2006 | 12:01 PM
kgn552004's Avatar
My cadi is a 1997, 29,000 miles, engine 32 V northstar. When it was in the shop, they replaced the fuel pressure regulator. The problem was still there so I took it back. they kept it over night so they could see how hard it was to start the next morning... they then cleaned spark plugs etc. at n/c...however it is still very hard to start on these cold mornings. Is there something else I should be looking at? Or is there something I can get to keep the engine warm?
kgn
Old Nov 8, 2006 | 01:15 PM
The first thing i would do is monitor the fuel pressure to see if its leaking down overnight.
If that was ok then i would monitor the engine sensors to see if everything was in spec.
Both require special tools and info to be done properly.
Old Nov 9, 2006 | 01:15 PM
kgn552004's Avatar
They replaced the fuel pressure regulator because they said it had an internal leak.......so i guess i need to monitor engine sensors...although i have no idea how to do that.
kgn
Old Nov 9, 2006 | 09:19 PM
just because they replaced the pressure regulator doesn't mean the fuel system is holding pressure.
The pump or an injector could be leaking down overnight.
Monitoring the engines senors requires a scan tool that has "engine data" capabililty.
Burbons_and_Lacs
Sep 7, 2007 01:03 AM
michaeldkania
Mar 16, 2007 04:52 PM
stelling
Jan 5, 2007 01:53 AM
bidness97
Mar 1, 2006 02:52 PM
bidness97
Nov 23, 2005 04:54 PM
