GM Bulletin 01-08-49-004 Intermittent/Inoperative analog instrument panel I/P Cluster
Old Aug 28, 2010 | 06:28 PM
danielpgeorge's Avatar
Default GM Bulletin 01-08-49-004 Intermittent/Inoperative analog instrument panel I/P Cluster
I have a 2001 Cadillac Deville DHS that I dearly love. Anyway, I've been having some problems with the DIC and was advised by JustAnswer.com that it may be related to GM Bulletin 01-08-49-004 Intermittent/Inoperative analog instrument panel I/P Cluster and that I should have this replaced. When I found out that it cost $575 to replace I thought there may be a better way. Anyway to make a long story short; All I did was to re-boot my onboard computer system by removing the positive battery cable for 5 to 10 minutes and then hook it back up. Now everything is working as it should. I don't know for how long but the point is that it is working properly.
Old Aug 29, 2010 | 08:39 AM
that is a standard procedure on any electrical issues BEFORE one starts thinking R&R parts.
good move.
you may also have grounding issues that often tend to create such issues and are often intermittent
Old Sep 21, 2010 | 12:25 PM
rockfangd's Avatar
good move indeed but I do not recommend disconnecting the positive cable without first removing the negative cable. very important
Old Sep 25, 2010 | 02:06 PM
Oh, why do you say to first remove the negative cable before removing the positive one? What is the danger? Thx, Dan.
juice
Nov 10, 2007 03:54 PM
stan38
May 14, 2007 06:53 PM
montemann
Jan 13, 2007 10:23 PM
prairecwby
Nov 29, 2006 05:20 PM
dubz01
Oct 26, 2005 06:42 PM
