Geting ABS Traction Control & Brakes Warning
I Have 2000 Cadillac Deville & 3 Weeks ago my ABS Traction Control & Brakes warning light came on has anyone had this problem before? What do i need to check to fix this?[sm=smiley20.gif]
Also an easy thing to check that could cause this is uneven tire pressures and tire tread thickness. if one tire is lower than the rest then its going to rotate at a different speed than the rest of the tires. causing the ABS/TC module to throw a traction control fault.
