Flushing the coolant system? Please Help!
Old May 16, 2007 | 09:18 PM
jrm347's Avatar
Default Flushing the coolant system? Please Help!
I want to drain and completely flush my coolant system. I have a few drain pans, and I purchased a bottle of the prestone super flush. Where exactly is the coolant to drain from? Is there a bolt or cap that twists off, or do I have to unhook a hose? Any help would be appreciated. Thanks
Old May 16, 2007 | 10:03 PM
Default RE: Flushing the coolant system? Please Help!
you didnt say what car you got, but
contents N/A
Old May 16, 2007 | 10:54 PM
jrm347's Avatar
Hey, sorry. 96 deville. I just want to backflush it with water to clean it out. I want to try using a sealant to hopefully stop from losing coolant.
Old May 17, 2007 | 12:05 AM
headgasket?
if you are doing a "repair" then ignore everythign i said and follow the instructions
EXACTLY as given.
i didnt know this was a resin seal job
it would have been better to continue the original thread rather than start a new one.
then we all know what we are doing from start to finiish
original thread:
https://www.cadillacforum.com/fb.asp?m=8495
Old May 17, 2007 | 01:20 AM
jrm347's Avatar
Thanks. Yeah, for the sealant, I will follow directions exactly as it says. Prior to this I want to completely flush the coolant system to maximize the effects of the sealant. I'm hoping this will stop the coolant loss for a while. If this doesn't work, I guess I'll have to actually fork up the cash and get the gaskets replaced. Ouch
Thanks
Old May 17, 2007 | 08:15 AM
please continue in the original thread.
it will then be a complete event
do let us know the outcome.
thanks
https://www.cadillacforum.com/m_8495/tm.htm
cady97dev
Aluminum Block V8s
Mar 20, 2009 08:10 AM
fireman_103
Jan 29, 2008 08:56 PM
wpbrink
Aug 3, 2007 05:47 PM
rantin63
Jun 10, 2006 11:06 PM
