Engine Temp !!!!
Old Jan 21, 2007 | 01:37 AM
atouchofclass's Avatar
Default Engine Temp !!!!
I have a 94 deville. where do you see where the engine temp is ??? Everything is Digital and I dont see where I can tell what my engine temp is at to know weather its overheating.
Old Jan 21, 2007 | 01:54 PM
misfit6794's Avatar
Default RE: Engine Temp !!!!
If you hit the information button on your dash, various readings will come across the screen under the speedo. Engine temp, amount of fuel used, rpm, etc. Car should be staying under 225. If your exhaust smells sweet, its burning coolant, and you have a bad head gasket.
Old Jan 22, 2007 | 09:12 PM
It wasn't the exhaust that was smelling sweet it's when you take the cap off the radiator it smells sweet.
Old Jan 24, 2007 | 01:46 AM
My engine temp and rpm doesnt show up on my display. just gas mpg average and timer and oil life etc
Old Jan 24, 2007 | 11:31 AM
misfit6794's Avatar
Thats definetly an issue. Check your owners manuel, those things should definetly be on that display. Could be your display maybe bad. I'd take it to a shop and have them check it out.,
Junkie2100
Sep 7, 2011 10:02 PM
68DevCon
Aug 22, 2010 03:50 PM
Roadking_bob
Aluminum Block V8s
Aug 13, 2009 08:02 AM
topaz92
Apr 14, 2005 02:36 PM
