deville starts hard
Old Nov 10, 2007 | 10:27 PM
flash's Avatar
Default deville starts hard
I have a 1997 deville concourse, and am having trouble starting it when it sits for a few days. Once it starts, it runs super and always starts good while using it, even the next morning starts good. I changed the fuel filter a couple of months ago, and I can hear the fuel pump run for a few seconds when you turn the switch on to start it, as it is suppose to. It cranks, but will not fire off, and I turn it off and try it again, and almost wants to, then on about the 3rd try, if I keep the starter cranking, it finally hits and starts, and then takes off, and then settles back down to a perfect idle. Any help would be appreciated.
Old Nov 10, 2007 | 11:00 PM
Default RE: deville starts hard
codes?
Old Nov 10, 2007 | 11:47 PM
flash's Avatar
Nothing!
Old Nov 10, 2007 | 11:56 PM
ORIGINAL: flash
no codes?
little info provided.
changed fuel filter before or after the problem?
i be checking fuel pressure. easy and gage is cheap.
But before that, i read this thread:
Old Nov 11, 2007 | 12:10 AM
flash's Avatar
I changed the fuel filter before this happened. I will checkthe filteragain, andcheck the pressure. Thanks
rmadigan91
Oct 24, 2012 09:10 PM
rickVick2k
May 15, 2010 10:08 AM
cpchase
Apr 24, 2010 07:50 PM
santaclaus
Dec 7, 2004 02:40 AM
