Check eng light
Old Mar 15, 2006 | 02:20 AM
AKA19047's Avatar
Default Check eng light
Hey everybody, new caddy owner here, i just bought a 1990 fleetwood, i got a check eng light, how can i decode this? the dealer said they can only decode after 1996 models and up. so mine being a 90 they cant decode it. any websites i can get it decoded from? \
Thanks for any help you can give me
Old Mar 15, 2006 | 08:03 PM
1997caddy's Avatar
Default RE: Check eng light
it's probably an o2 sensor or egr valve malfunction. if the light stays on and does not flash, that's probably your problem.
Old Mar 15, 2006 | 08:17 PM
AKA19047's Avatar
thanks 1997 caddy, im having the EGR replaced tomorrow hopefully that does it.
Old Apr 4, 2006 | 10:41 PM
hagrid's Avatar
i agree with the above posts, check your oxygen sensor, it might need some replacement.
Old Jul 5, 2006 | 04:45 AM
onecool's Avatar
If it has a cpu in it probably an ODBI and not ODBII if so you can short 2 pins I think A and B together or to A to Ground and you should get some flash codes on your dash. The Check eng light will flash like 2 times pause 3 times =23 this is an example it will flash codes 3 times and move on to the next code.
Just look up ODBI or ODB1 as it’s called. On Google.
Old Apr 10, 2007 | 10:31 PM
jocko777's Avatar
i have a 1990 fleetwood 4.5 and codes can be found online as well as capable of reding them with the heater conrols . if they are telling you they cant read them then they arent mechanics or you have a 1990 cadillac different than the others i have seen . all of what you need to know is online or in the factory manual . you can even turn on and off injectors to troubleshoto a miss.
Old Apr 15, 2007 | 10:00 PM
onecool's Avatar
funny he said he has a 90 cadillac LOL.
99CaddyNH
Jul 17, 2008 06:36 PM
tcfox
Jun 6, 2007 08:59 PM
LAR414
Mar 19, 2007 10:26 AM
bgmkdg
May 20, 2006 11:24 AM
