98 deville wiring diagram????
Old Aug 13, 2010 | 03:50 AM
showtime's Avatar
Default 98 deville wiring diagram????
Does anyone have a good wiring diagram for a 98 deville as I am experiencing some electrical woes.. Thanks Eddie
Old Aug 13, 2010 | 07:39 AM
gmtechs's Avatar
what one do u need
or what is happening
Old Aug 13, 2010 | 02:52 PM
showtime's Avatar
I need the wiring manual for a 1998 Cadillac Deville pertaining to the rear lights (taillights, stop lights, turn signals, and reverse lights). I've checked the fuses; changed the bulbs, but it didn't help. The problem we're having is when either turn signal is on, the front were as they should; however the rear are extremely dim. Once the brake pedal is applied, the turn signal ceases to operate; however the brake lights don't work either. The reverse lights are extrememly dim to the point where you can't tell they are on. I appreciate any help as I am looking for a bad ground and don't know where to begin. Thank you, Eddie
Old Aug 13, 2010 | 03:15 PM
gmtechs's Avatar
ground is In the left rear of the rear compartment, near the tail lamp assembly
there is a splice
In the body harness, approximately 29.5 cm (11.61 in) from the C420 breakout
c420
Body harness to the left tail lamp harness, in the left rear of the rear compartment, near the tail lamp
Old Aug 14, 2010 | 05:58 AM
showtime's Avatar
It was the ground wire in the rear....Thank you very much for your help as I was focusing most of my time looking for a ground coming off the fuse panel under the hood.... I really appreciate it...
robotic_junky
10
May 9, 2021 09:18 PM
caddy1463
Jun 21, 2009 01:42 PM
black99
Nov 2, 2007 12:14 PM
vocatus
Oct 22, 2007 06:25 PM
mr cig
Oct 28, 2006 06:23 PM
