98 deville securty problems, please help.
Old May 13, 2007 | 06:31 PM
cadirydin's Avatar
Default 98 deville securty problems, please help.
i have a 98 deville, had it for about 9 months now. never had any problems till yesterday... does anyone know what to do about, theft system problem, car may not restart, then the servie airbag light comes on , then the traction control light comes on, and the digital diplay just has line where the numbers are supposed to be for the ac,miles per gallon, and remaining fuel........oh and the ac comes on and i cant turn it off.... has anyone had this problem? if so please help oh and it doesnt do it all the time after about 10-15 min of driving it comes on all at once, the everything goes back to normal after about 15 min. then it just goes back and forth, thanks in advance for the help
Old May 15, 2007 | 07:35 AM
cadirydin's Avatar
Default RE: 98 deville securty problems, please help.
problem solved it was the battery not putting out enough voltage,
Old May 15, 2007 | 07:58 AM
thanks for providing outcome and solution.
ORIGINAL: cadirydin
Old May 15, 2007 | 10:04 PM
Katzmans Caddy's Avatar
Excellent resolution, do you know what voltage it was putting out? I see my car generally between 13.2 and 14.7 volts and all system are go.
Old May 16, 2007 | 04:00 PM
cadirydin's Avatar
ok back again, it was just a tep. fix, because its doing it again! damn it! i even went and had a new key made too, at the dealer so 48 dollars later.......and nope, nothing different. my voltage is around 13.5-14.5 so im open to any and all suggestions......... i think im ready to give up on the cadi's!!lol
Old May 16, 2007 | 08:42 PM
Dealer said key just like I did , dealer said battery and that all worked for a while. Try disconnecting the battery again. It could be a flaky computer however.
Old May 16, 2007 | 08:53 PM
91parkave's Avatar
go through your fuses there up front and in the trunk where the back of the rear seats are
Old Jun 2, 2007 | 08:22 PM
cadirydin's Avatar
OK HOW BOUT THIS, PROBLEM SOLVED... ITS GONE GOT RID OF IT, BUT I DECIDED TO STAY WITH THE CADI'S NOW I GOT A 2007 CTS. SO I SHOULDENT HAVE ANY PROBLEMS FOR A WHILE.... THANKS FOR ALL THE INPUT
Old Jun 3, 2007 | 07:26 PM
what did you get with it? pictures ?
ORIGINAL: cadirydin
....................... NOW I GOT A 2007 CTS. SO I SHOULDENT HAVE ANY PROBLEMS FOR A WHILE.... THANKS FOR ALL THE INPUT
Old Jun 5, 2007 | 08:14 AM
cadirydin's Avatar
i tried to post some pictures but it says file is to big, i tried resizing it too
HAMMbone89
Feb 16, 2015 11:36 PM
Cadillac Al
Nov 30, 2008 02:56 PM
99sts
Oct 18, 2007 08:36 PM
chevyboy572
Apr 4, 2007 04:36 PM
muzik4life
Mar 6, 2006 06:10 PM
