A couple problems. Please help.
Old Apr 3, 2007 | 06:38 PM
chevyboy572's Avatar
Default A couple problems. Please help.
I just bought a 1992 Cadillac DeVille today and its already giving me crap.
1. The car sometimes refuses to shift from 2nd to third.
2. The display goes crazy sometimes. it jumps from 0 to 65 to 11 to 25 when im barely moving. It sometimes doesnt want to show anything.
3.It cranks slow. (Might be battery or Alt.)
4. When i turn it off, there is a growling noise and I think it is the susp. leveling system. But it foes on, then off, then on again.
Help??? Thanks.... Eric.
Old Apr 3, 2007 | 08:08 PM
Katzmans Caddy's Avatar
Default RE: A couple problems. Please help.
I am sure you will get it running well, remember it is 15 years old.
1. Check your fluid level, check all fluids since you just got it.
2. Get a slavage display, that one is flaky.
3. I think Caddy's do crank slow, lots of toque in the starter, but could be battery or connections.
4. Probably compressor purging.
Old Apr 4, 2007 | 04:36 PM
92_Daddylac's Avatar
my 92 deville cranks somewhat slow but it used to crank really slow due to bad battery, also the "growling" noise is your suspension leveling mine does the same and also that was wearing down my bad battery causing my car to crank slow too. Not too sure about your display but if you have a "u-pull it " junk yard you can get a display pretty cheap, about $30-$40 if you get one from the dealer it may be like $200 or more. but i was always told that thedigital display inolder devilles such as ours are notorious for going out. mine hasnt but you never know.
99 Seville STS
Dec 28, 2012 02:18 AM
Cadillac Al
Nov 30, 2008 02:56 PM
sonotech
Aug 29, 2007 08:06 PM
mikemike32170
Oct 27, 2006 11:57 AM
FredMaxwell
Mar 9, 2006 05:23 AM
