98 Cadillac Deville OverHeating Issues
Old May 6, 2013 | 10:33 PM
Darren_'s Avatar
Default 98 Cadillac Deville OverHeating Issues
Hey Guys, My First Time Using This Forum And I need your help
i have a 98 cadillac deville 145,000 miles
ive replaced the thermostat, water pump, flushed my cooling system, replaced some gaskets and housing near the water pump where my coolant was leaking out. new air filter, spark plugs, and an oil change.
My Car is reading the codes p0507 and p0603
my car runs great other then one thing
it doesnt over heat while im driving but while im in traffic, at a stop light or just idling in the driveway it over heats. both fans are coming on.
i have tried everything i know to try and it still hasent fixed the problem. can someone please help me
Old May 6, 2013 | 11:41 PM
Katzmans Caddy's Avatar
At this age you have to be looking to the head gaskets.
Old May 7, 2013 | 07:49 AM
Darren_'s Avatar
its not the head gasket,
no white smoke coming out
no water in my oil.
the car runs great. and smooth
it isnt loud at all
Old May 7, 2013 | 07:50 AM
Darren_'s Avatar
my radiator is leaking fluid.
could this be the issue.
but i just dont get it. only over heats while idling.
driving it does what its supposed to do
Old May 7, 2013 | 01:53 PM
Cadsforfun's Avatar
Default Overheating
Have you done a pressure test on the rad. If you are not maintaining pressure then the boiling point will be lower than it should be.
StevenMatthews253
Sep 18, 2015 02:10 AM
Grant A. Van Vranken
Oct 26, 2013 06:21 PM
dfb52764
Aluminum Block V8s
10
Jan 15, 2009 06:16 PM
JimMayor007
Sep 17, 2008 06:34 PM
abaines12345
Jun 8, 2008 11:02 PM
