'97 Deville, runs rough with A/C on
Old Jul 21, 2007 | 12:22 PM
  #11
FLCaddytech's Avatar
Default RE: '97 Deville, runs rough with A/C on
ORIGINAL: FLCaddytech
if you have been driving for a year with the SES light on, then you have no idea how many other codes may have set since the last time you had it scanned.
Step 1.
Scan for codes
I do not have a scanner to pull codes, although I do know it needs an O2 sensor because the SES light is on and the scanner I borrowed a year ago said that. Could the O2 sensor be causing this problem?
Step 2.
Repair the obvious problem first then move on to the next issue.
The o2 sensor may or may not be the problem you are now experiencing. I wouldn't diagtherunning conditionat my shop unless you fixed the o2 code first.
Old Jul 21, 2007 | 12:52 PM
  #12
DeFormula's Avatar
OK, here are the codes. It sounds like I probably need two O2 sensors to start...
P0139 - O2 sensor ckt slow response Bank 1, Sensor 2 (also Bank 1, sensor 1 but I forgot to write down the code number)
P0300 - Random / multiple cylinder misfire detected (may have occured because I hooked up the plug wires wrong when I put on a new set a few months ago)
P0135 - O2 sensor heater circuit malfunction Bank 1, Sensor 1
P0141 - O2 sensor heater circuit malfunction Bank 1, Sensor 2
P1139 - Manufacturer controlled fuel and air metering
Go for it tech meisters.
Bank one is the bank closest to the frt of the car, correct (?), or whichever starts with cykinder one, I haven't looked at it in a while.
Thanks guys.
Dave
Old Jul 21, 2007 | 03:14 PM
  #13
You have five codes saying the o2 sensors are a problem.
Unless you had some very weird wiring problem I'd go with 2 new sensors.
Bank 1 is the back head. Passenger rear 1 3 5 7
Old Jul 21, 2007 | 08:58 PM
  #14
DeFormula's Avatar
Thanks FLCaddytech. I agree, I'll put in two new sensors and go from there. No weird wiring probs that I know of. This is a very clean unmolested car. I'll let you know what happens.
EasyDawg
Apr 1, 2015 12:10 PM
sbrant01
Mar 17, 2015 10:42 AM
georgewerr
Jun 13, 2008 04:18 PM
scottncincy
Mar 29, 2008 05:34 PM
Seville650
Aug 24, 2006 03:24 PM
