97 Deville Concourse
Old Jan 1, 2008 | 04:37 PM
flash's Avatar
Default 97 Deville Concourse
Can anyone tell me the best way to lower the fuel tank and replace the fuel pump on a 1997 Cadillac Deville Concourse? Thanks
Old Jan 1, 2008 | 05:25 PM
Default RE: 97 Deville Concourse
How much fuel is in tank? It will need to be below 1/4 to remove tank in your driveway or detached garage. DO NOT TRY TO DROP TANK IN ATTACHED GARAGE! Raise car a high as possible. Reposition exhaust, remove heat shield, disconnect fuel lines, filler hoses, electrical connector, place floor jack under tank remove 4 bolts that holds straps and lower tank.
Old Jan 3, 2008 | 09:16 PM
flash's Avatar
Slowroll, Thanks for your reply. I have a well equipped detached shop, so should not be a problem. I even have a transmission jack I borrowed, so that should work good. Just trying to get a good idea what I am facing. Thanks again for your help.
boo149st@hotmail.com
Jul 10, 2012 10:36 AM
rgmatzke
Jul 18, 2008 10:23 AM
potsynolls
Dec 31, 2007 06:14 PM
chewyman1
Dec 5, 2006 10:25 AM
giusto
Nov 30, 2006 02:20 PM
