96 Deville 4.6l running hot
Old Nov 10, 2017 | 06:38 PM
CaptainDeville's Avatar
Default 96 Deville 4.6l running hot
Replaced the water outlet on the water pump body because of leak near one'
of the 10mm bolts. Reused existing thermostat....replaced the seal. No leaks.
Put 3 crushed Barrs tablets in the lower hose and buttoned it up. The vehicle
is now runnin hot 218 to 222 on both local and highway speeds. Removed the purge line at the coolant reservoir and nice steady stream of coolant.
The stream increased when vehicle is accelerated. I guess that eliminates
any problems with purge line. Ordered new AC Delco radiator cap and thermostat. Radiator is one year old. Is it possible that the tablets may have
clogged the radiator or the thermostat? Any ideas or comments are appreciated
Mags1
Nov 19, 2010 07:37 PM
samdun124
May 6, 2010 07:40 PM
needhelp
Jun 15, 2005 11:51 AM
needhelp
Dec 16, 2004 06:12 PM
