95 concours
Old Jan 19, 2010 | 05:58 PM
jdaugherty3's Avatar
Default 95 concours
hey my 95 deville concours will not start. it just clicks. All the lights, radio, have full power, the battery is fine. So, it's probably the starter. Where is the starter, under the intake? anytips?
Old Jan 19, 2010 | 06:13 PM
Texan4Life's Avatar
Possibly. I would double check the battery though. I would disconnect and clean the terminals. and look over the wiring.
And if possible put a volt meter on the battery and see what the voltage does when you hit the starter.
Does all the lights, and radio still have full power while trying to start the car?
If all that checks out then I would say yeah a starter.
I had the same problem with may 90 deville. starter seemed to drag, clean the terminals that help a little. come to find out the positive wire under the insulation was all corroded.
and another time it it would just click and turns out the battery had 12.5V, hit the starter it would go down to like 9 or 10.
Old Jan 20, 2010 | 08:23 PM
tried all that, battery is fine. So the starter is under the intake? any tips or tricks to make this job easier?
dduck22
Apr 19, 2007 08:20 PM
LCD
Aug 20, 2006 08:05 PM
mreasy
Aug 20, 2006 11:53 AM
shortypop1
Apr 28, 2006 03:02 PM
lovinmylac
Feb 16, 2006 05:35 PM
