81 Coupe trans ?s
I have a 368ci(6.0) engine and I believe a th400 trans. I think I need to replace it. I would like to put a beefed up 700r4 in it, or mabey a th350 cause I have one. I was told that a 700r4 won't bolt to the 368ci. Is this true? I thought all GM's small blocks and big blocks used same transmissions. A little advice please.
Hey Coupe: the only transmissions that I have listed for this engine are the 200, the 200C , the 2004R, the 350, the 350C, the 400 . That is assuming you don,t have front drive. Hopethat helps.
Okay, then the th350 in my garage should bolt up. Is there a adapter to make the bell housing of a 700r4 bolt to the 368. I would really like over drive for mpg purposes. So thenno Caddy big block ever had an over drive trans? That doesn't seem quite right to me.
simjack
Jan 9, 2005 10:04 AM
