1993 Sedan Deville
Old Sep 29, 2010 | 07:04 AM
hgoodwiniii's Avatar
Default 1993 Sedan Deville
Hello, I hope everone is well. I have a question for a 1993 Sedan Deville. My A/C control and Fuel Data Center units seem to have gone out at the same moment. With that said, I cannot tell how much fuel is in the car nor does the a/c or heater come on. I checked the owner's manual and both the Fuel Data Center and A/C seem to run on the same fuse (#7). I checked and changed the fuse and it is good. Can anyone offer any other advice on what the problem may be? Thanks.
Old Sep 29, 2010 | 07:12 PM
Not simple, do to multiple possibilties. FDC, HVAC CONTROL HEAD, HVAC PROGRAMMER, BCM, OR ECM can cause this to happen. Sometimes you can unplug them one at a time and try to determine which is causing it.
Old Sep 30, 2010 | 06:49 AM
Thanks. Where and what is the FDC?
Old Oct 22, 2010 | 09:11 PM
I changed the BCM and the fuel center started blinking. The air would try to come on when I turn the car off then both stopped working. The old unit smelled burned and so did the chip inside smell burned. However, the dealership says the prom is not available. Any idea where I can find the a chip? Thanks.
Old Oct 23, 2010 | 09:50 AM
Adams' Apple's Avatar
Fuel Data Center.
Where did the BCM come from? New or used?
You may have wiring/component issues that need to be corrected before installing a new/different BCM. Most all of the dash display modules "talk" to each other, and a problem in one can certainly cause a problem in another.
Don't know where you might be able to locate a "chip", or if it's even available, except in a used module...
Old Oct 23, 2010 | 11:56 AM
Yes, it's a rebuilt one from the dealership. I found the chip. It's like $269. I would like to have the old one bench tested before I proceed. Any ideas on where I can get bench tested? Thanks.
Old Aug 14, 2012 | 11:49 PM
Randy Clay's Avatar
I'm having the same problem with my fuel data center and climate control. I know i have power to them cus when i turn my headlights on i have lights coming on in the units but nothing is showing up on the faces. mine is a 93 devill sedan. Anyone have any ideas as to what is causing this issue?
Old Aug 15, 2012 | 12:00 AM
Randy Clay's Avatar
I am also having a problem with my fuel data center and my heater copntrol unit. I know I have power going to them cus when I turn on my headlights I got lights on in the units (i removed the units and saw the lights). But I dont have anything showing up on the face of these units. Anyone have any ideas?? 93 deville sedan is what I have.
Old Aug 24, 2012 | 04:17 PM
Randy Clay's Avatar
where is the BCM located?
hgoodwiniii
Feb 25, 2010 08:22 PM
metalcaddy
Jan 14, 2010 11:55 PM
hgoodwiniii
Aug 10, 2009 10:50 PM
hgoodwiniii
Nov 7, 2008 12:35 PM
Cadillac Pimpin
Sep 22, 2007 01:32 PM
