1965 DEVILLE CONVERTIBLE QUESTION
Old Nov 22, 2007 | 10:04 PM
BLANCK88's Avatar
Default 1965 DEVILLE CONVERTIBLE QUESTION
what type and where do I put the fluid for the roof motor in a 65 deville convertible?
Old Dec 11, 2007 | 04:38 PM
threnc's Avatar
Default RE: 1965 DEVILLE CONVERTIBLE QUESTION
My 1971 Fischer body service manual for Cadillacs states that you put type A automatic transmission fluid in the reservoir which should be located behind the back seat area on the pump motor. You want to attach a line to the filler port on the reservoir then run itdown into a container filled with your transmission fluid that is lower than your reservoir. Then you want to run the top down then another 15 to 20 seconds until the pump motor changes sounds. This indicates the reservoir is filled.
ralphiedee
Eldorado Biarritz
Oct 22, 2013 09:09 AM
Frankn
Sep 10, 2012 11:43 PM
toazt
May 7, 2011 01:47 PM
65CAD
Sep 21, 2009 05:55 PM
Kaotickid7
Jun 1, 2008 07:12 AM
