01 deville won't start on first try
Old Apr 23, 2007 | 01:59 PM
zipper's Avatar
Default 01 deville won't start on first try
I starting having this problem a couple of days ago. It doesn't happen everytime. I try to start the first time it does nothing but on the second try it starts and runs fine. Battery volts are running 14.6-14-9 Has anyone had this problem or can give me insight on what's causing this.
Your help will be greatly appreciated..
Thanks
Old Apr 23, 2007 | 07:04 PM
Katzmans Caddy's Avatar
Default RE: 01 deville won't start on first try
Try checking the battery connections first, make sure they are clean and tight. Seems all is charging well once it fires up.
Old May 22, 2007 | 10:13 PM
barbaranna's Avatar
not a mechanic or anything like that but i had a problem that was pretty much the same i was using 89 gas and was having the problem i put in 93 and have not had the problem since fires up right on the first try
alojdiradio
Apr 5, 2015 12:41 PM
ocwoody25
Aug 21, 2010 10:13 PM
Jan 6, 2008 03:57 PM
G.A.R.Y.
Dec 6, 2007 08:56 PM
