01 Deville Dts Missing.
Old Oct 24, 2007 | 02:57 PM
dropped720s's Avatar
Default 01 Deville Dts Missing.
Hey hopfuly someone can help me out i have a 01 Deville DTS with 80,000 miles and it has a slight miss at idle. i thought it might be plugs so i had the plugs replaces and it is still the same i have had the problem now for about 6mo. any help is appricated. Thanks in advance.
D
Old Oct 24, 2007 | 07:24 PM
Default RE: 01 Deville Dts Missing.
SES light on? codes stored? Vacuum leak?
Old Oct 24, 2007 | 08:50 PM
no light on, no codes either. anything else slowroll? thanks man.
Old Oct 25, 2007 | 08:43 PM
A scanner that can read misfires and o2 would be very help full. As far with out one check plugs see if 1 looks different than than others, rust on coil tips, vacuum leaks, and heavy carbon build up at throttle plate.Cleaning injectors may help.
Old Oct 25, 2007 | 09:20 PM
my scanner reads misfire and o2 and everything seems to be ok according to it. thanks
D
Old Oct 25, 2007 | 09:27 PM
What are short and long term fuel trends.Broken front motor mount?
floaterone
Feb 21, 2019 03:45 AM
Mike D
Nov 28, 2012 07:16 PM
tedalmeida
Aluminum Block V8s
Jun 14, 2009 08:26 AM
nathan_g
Nov 23, 2008 06:40 PM
chris
Jan 25, 2008 08:26 PM
