'00 Deville Oil Use
Old Mar 20, 2006 | 10:10 AM
prcouture's Avatar
Default '00 Deville Oil Use
I have an '00 DHS that uses a bit of oil. Called the dealer awhile ago and he stated it's normal to use a quart every 1000 miles. Sounded crazy, but heard this from a couple of other guys, too. I'm nearing 100k and it seems to be getting worse. Don't see blue smoke, not leaking, etc. Anyone else having the same problem? It runs great, no knocking, pinging, nothing. Wonder if an oil additive might help. Any ideas. Thanks.
Old Mar 21, 2006 | 01:43 AM
Brolinger's Avatar
Default RE: '00 Deville Oil Use
My OO DHS uses a quart every thousand or so. It doesn't leak, blow smoke, or foul plugs. Oil is cheap. I just check it every third fillup or so. My Caddy mechanic (specialist but not a dealer) says it's normal. Something about the ring design. I would not worry about it as oil is cheap and easy to put in. It certainly isn't worth doing any engine work over.
Check recent threads regarding tranny shifting problems, including my response . A complete flush and additive smoothed mine out very nicely. Your car may need the same.
Bengal313
Aug 1, 2013 10:34 AM
FeltNotHeard
Automatic Transmissions
Apr 27, 2012 04:08 PM
sixxdogg
Nov 5, 2008 12:15 PM
brick
Jul 28, 2007 12:10 AM
theatreman
Apr 15, 2007 07:33 PM
