Service Air Bag Warning
2004 CTS
Any idea why my message is coming up and then shutting itself off every few minutes? Do I have to take it into the dealer? Doesn't do this all the time but has started happening alot more?
You will have to take it in to see which airbag is causing the fault. It has been happening to me and I had Onstar do a diagnostic on it. I was told that the airbag may NOT deploy if you are in an accident. It does not mean that it will just pop out on you...
It is a safety hazzard and should be checked....
You have some type of malfunction and needs to be repaired. Does it seem to come and go? If so does it change when you turn the steering wheel? Have someone connect up to the ALDL plug and go to the SIR or airbag system to see what is wrong
